Official integration: stromleser.one extends clever-PV with meter-accurate real-time data
The stromleser.one is now officially compatible with clever-PV . This allows us to directly connect our precise electricity meter reading with an intelligent energy management system for photovoltaic households.
The new interface allows clever-PV to receive high-resolution real-time data directly from the grid connection point – and to control consumers even more precisely and efficiently.
Why this integration is particularly valuable from a technical perspective
Unlike purely inverter-based solutions, stromleser.one records energy flows directly at the digital electricity meter. This means:
- Precise measurement of grid consumption and feed-in
- Precise representation of actual household consumption
- Manufacturer-independent data collection
- Reliable decision-making basis for automated control
The measured values are continuously transmitted to clever-PV and integrated there into intelligent control logics.
Intelligent PV control based on real meter data
With the live data provided by stromleser.one, clever-PV can react flexibly to current energy flows. Excess solar power is used automatically by controlling devices such as:
- Wallbox
- heat pump
- heating element
- Battery storage
- They can be activated selectively as soon as sufficient PV power is available.
This creates a dynamic interplay between generation, consumption and storage – with the aim of significantly increasing self-consumption and sustainably reducing electricity costs.
Greater transparency for complex energy systems
Especially in modern households with multiple large consumers or dynamic electricity tariffs, a precise data basis is crucial.
The combination of stromleser.one and clever-PV offers:
- Complete transparency of all electricity flows
- Fast response times thanks to minute-by-minute data
- Optimized use of PV surpluses
- Improved efficiency of the entire plant
Thanks to its manufacturer-independent architecture, the integration is suitable for both new installations and existing PV systems.
A step towards holistic energy management
By connecting to clever-PV, we are specifically expanding the application possibilities of stromleser.one in the areas of PV optimization, smart home integration and intelligent load management .
Our aim is not only to make energy flows visible, but also to actively utilize them – for greater self-sufficiency, greater efficiency and sustainable energy use in your own home.
Advantage for energy reader customers
As part of our community, you also benefit from 3 free months when you take out a clever-PV annual subscription .
Simply click here or redeem the code "stromleser" in the web app (Attention: not in the mobile app).
All information on integrating stromleser.one into clever-PV can be found in our compact energieleser.docs – from setup and activation of the interface to tips for optimal use of real-time data.
