Wasser
wasserleser – your smart water meter for complete transparency
wasserleser – dein smarter Wasserzähler für volle Transparenz - energieleser
Water flows – but where exactly?
How much water do you really use? And what happens when a tap is dripping unnoticed or a pipe is leaking?
A single, continuously dripping faucet can waste up to 15 liters per day – that's an incredible 5,500 liters per year.
With the water reader, you can make your existing water meter smart and keep an eye on your water consumption in real time.
water meter reader
Problem
Water is one of the most valuable resources of our time – but we often only realize too late when we are wasting too much of it. Conventional water meters are analog and passive. They provide no warning, no live data , and certainly no transparency .
Whether a tap is dripping, a toilet is constantly running, or a pipe is leaking: many losses go unnoticed – and accumulate over weeks to hundreds of liters and high costs . For households, this means: no control, no overview, no early detection.
Solution: wasserleser
The wasserleser transforms your existing meter into a smart, digital device – without any modifications.
As an intelligent reading head, it detects every rotation of your water meter and transmits the data to the app in real time. You can see exactly when and how much water is being used – whether in the morning while showering, at noon while cooking, or at night when everything should actually be standing still.
Instead of just knowing the meter reading, you get a feel for your daily life : You recognize consumption peaks, identify continuous runs and are immediately notified of unusually long or constant consumption . This allows you to intervene early – before undetected losses become expensive.
The wasserleser gives you what conventional meters don't offer: transparency, control, and awareness of your water consumption – intuitive, understandable, and accessible everywhere.
The reading head for your water meter.
Your benefits with the wasserleser
🔧 Plug & Play Installation
Simply plug it in, connect the USB-C cable, open the app – and you're done.
📱 Real-time consumption in the app
View your water consumption live and use clear graphics for more transparency.
💧 Early warning system for leaks
Receive instant notifications for unusual usage.
🏠 Compatible with common water meters
Fits many standard models – ideal for renters and owners.
🌍 Smart Integration
Use the water reader together with the electricity reader and gas reader in just one app.
🇩🇪 Made in Germany
High quality, precise measurement and data protection according to European standards.
Installation: In 4 easy steps
  1. Insert adapter – if necessary, simply attach the appropriate adapter to the water meter.
  2. Place the water reader on top – position the reading head directly above the red rotating wheel.
  3. Connect the power supply – plug in the USB-C cable and connect it to the power adapter.
  4. Start the app – connect in the app and read your consumption digitally immediately.
Your water meter will be smart in just a few minutes – no tools, no modifications, no expert knowledge required.
Attaching and installing the water meter.
Compatibility
The wasserleser works with meters that have a visible metal plate . If this plate is missing, your meter is currently not compatible.
A practical adapter set included in the scope of delivery ensures that the water meter reader sits securely on many meter types.
Compatibility of the water meter
The app: Everything at a glance
The energieleser app turns the wasserleser into your digital control center.
  • Live consumption in m³ or cost
  • Graphical analysis of your water consumption history.
  • Notifications for unusual usage
  • Manage multiple meters – ideal for houses with multiple apartments or meters
  • Integration with electricity meter and gas meter – all energy data in one app
Electricity meter reader app
Conclusion
With the wasserleser, you can quickly and easily transform your analog water meter into a smart, digital device. This allows you to monitor your water consumption in real time, anytime – whether at home or on the go. Thanks to intelligent consumption monitoring, you can immediately detect leaks, continuous running, or unnoticed drips, thus not only avoiding water waste but also sustainably reducing your costs . Via the user-friendly energy reader app, you receive all data directly to your smartphone, keeping your consumption under control at all times and allowing you to optimize your usage behavior – for more control, efficiency, and sustainability in everyday life.
FAQ - water reader
Does the wasserleser require Wi-Fi?
Yes, the water meter transmits the data via Wi-Fi to the cloud so that it can be displayed in the app. A stable connection is therefore necessary.
How is the wasserleser powered?
The water meter reader requires a permanent power supply via the mains. A suitable power supply and a connecting cable are included, so you can get started right away.
Which water meters is the wasserleser compatible with?
The water meter reader is compatible with most standard water meters, especially models with a visible rotating disc.
You can find a detailed overview in the story under the section "Compatibility". There we explain exactly what you need to pay attention to - including example pictures and measurement instructions.
Can I install the wasserleser myself?
Yes, absolutely! Installation is child's play and takes just a few minutes – no tools required. Simply attach the included adapter to your water meter, plug in the water meter reader, and connect it via the app. A detailed step-by-step guide will help you.
Can the wasserleser be integrated into Home Assistant?
Yes – the integration is firmly planned and will definitely happen. We are already working on it intensively. However, the interface may not yet be available at the time of delivery. In this case, it will of course be provided later via a software update and will then work directly with the hardware purchased here.
Dein Stromverbrauch im Blick: Wie der stromleser Lesekopf im Alltag hilft - energieleser
Energiewende einfach verstehen – und wie der stromleser dabei hilft - energieleser
