Setting up stromleser.tasmota on your digital electricity meter: Step by step
stromleser.tasmota am digitalen Stromzähler einrichten: Schritt für Schritt - energieleser
In this guide, you will learn how to install the stromleser.tasmota digital electricity meter, set up Tasmota, and then integrate the stromleser into the stromleser app.
Step 1: Activating the electricity meter with PIN
If you haven't already done so, you must first enter your PIN.
Without the PIN, many meters only display the meter reading – Real-time values are not displayed .
1. Request PIN: from the metering point operator
2. Start PIN entry: either with a flashlight or with special PIN apps.
PIN entry app digital electricity meter
3. Activation: Shine the flashlight on the beam for a few seconds.
DO interface digital electricity meter
4. Input: Each light pulse represents a number (e.g., 5 pulses = number 5)
Flashlight light digital electricity meter
PIN entry for digital electricity meter
⚠️ In order for the electricity meter reader to be able to transmit data continuously, the PIN option must be set to “Off” and the information interface to “On” on some meters.
Information interface of digital electricity meter
Step 2: Attach the stromleser.tasmota to the meter
1. Attach the metal disc: Glue the metal disc onto the for a secure hold. DO position at the counter.
Attach metal disc to D0 interface
2. Attach the electricity reader: The power meter is attached magnetically.
3. Check alignment: Align the logo horizontally so it is legible.
Attach the electricity reader to the digital electricity meter
If the plastic stem is in the way, you can also mount the power reader in the 45° angle attach.
Mount the electricity reader at a 45° angle.
Important: The right light source your meter must Receiving diode the stromleser overlap.
Step 3: Connect to Wi-Fi & set up Tasmota
1. Connect to Tasmota Wi-Fi: Open your smartphone's Wi-Fi settings and select the Tasmota network out of.
2. Open the configuration page: It usually appears automatically. If not, enter the address in your browser. http://192.168.4.1 input.
Open configuration page in browser
3. Enter home network: Select home network, enter Wi-Fi password, and click Save.
Add home network to Tasmota interface
4. Note the device IP address: After saving, the device's individual IP address is displayed (often only for about 20 seconds). It is best to write it down or take a photo immediately.
Tip: Press and hold the IP address to open it in a new window, or enter it manually in your browser.
Note the device's IP address.
⚠️ Important: Do not perform a firmware update in Tasmota – this can damage the firmware. There are separate instructions for reflashing.
Step 4: Reset stromleser (if necessary)
If the connection fails or the IP address cannot be opened:
1. The stromleser 7x briefly disconnect from the power supply and plug it back in.
2. Then restart the installation.
3. If it still doesn't work: Contact support info@energieleser.de
Step 5: Configure script (counter profile)
1. Open the website: https://energieleser.de → Rider "Compatibility"
Find your perfect script at stromleser.de
2. Select script: Select the manufacturer and meter model of your meter (e.g. Landis+Gyr E320).
3. Copy script and switch to the Tasmota interface
Select and copy the appropriate script for the counter.
4. Insert script:
  • Menu Tools → Configure Script
  • Delete existing text
In the menu - Tools - Configure script
  • Paste copied script
  • Check the box next to “Enable script.”
  • Save
Check the box to activate and save the script.
5. Return to the main menu
6. Check data: Meter data should appear after a few seconds.
Return to the main menu and the counter data should appear there.
Common script errors
Spaces at the beginning or end of the script.
Common errors: Spaces at the beginning or end of the script.
Forgot to check “Enable script.”
Common mistakes: Forgetting to check the box to activate the script
For a single stromleser.tasmota, no changes need to be made to the script.
Will one or more stromleser.ttl If an additional connection is made, the script must be extended.
Example: If the current reader.ttl is connected at the top right, the script must contain the IO ports 5 4.
Example script for two counters
You can find the complete overview of the I/O ports here:
Complete overview of I/O ports
Step 6: Integrate into the stromleser-App
1. Install the app:
From the App Store or Google Play Store stromleser-App download
Download the power reader app
2. Register/Log in:
  • via Google or Apple or
  • with e-mail (First name, last name, email, password) → Register → Enter verification code
Registration in the Stromleser app
3. Add device:
In the app stromleser → stromleser.tasmota choose
Add stromleser.tasmota
Browse network or manually enter IP address
Add Tasmota device
Select stromleser.tasmota, assign a device name, click Connect click
4. Advertisement:
The values will local transferred. You'll only see them if your smartphone is in same Wi-Fi like the electricity reader.
The values are transferred
The stromleser.tasmota will then appear in the Home section of the app, where all values are clearly displayed..
stromleser.tasmota appears in the app's home section.
Troubleshooting
  • No live data: PIN not set? → PIN option off & Information interface On check
  • Tasmota page does not open: With Tasmota Wi-Fi Connected? Otherwise http://192.168.4.1 manually call
  • Forgot device IP: In the Router Check or reset the power reader (7x power off)
  • No data after script: Correct counter model selected? Script activated? No spaces inserted?
  • Multiple devices: Script to correct IO pins extend (e.g. IOTS54)
  • App cannot find device: Are the smartphone and power meter on the same Wi-Fi network? Possibly. Enter IP address manually
Support
If something goes wrong, it's usually just a minor issue. Get in touch with us – we'll help you quickly and easily.
Have fun! Read electricity !
Home Assistant Integration für stromleser.one - energieleser
Home Assistant Integration für gasleser - energieleser
