Hager
Hager Zähler TASMOTA Scripts - stromleser.tasmota
Hager Meter Scripts
Hager EHZ161
->sensor53 r
+1,3,o,16,9600,EHZ161,1
1,1-0:0.0.0*255(@#),Meter Number,,meter_number,0
1,1-0:1.8.0*255(@1,Verbrauch,kWh,Pin,4
1,1-0:2.8.0*255(@1,Einspeisung,kWh,Pout,4
1,1-0:32.7.0*255(@1,Volt_L1,V,volt_l1,2
1,1-0:52.7.0*255(@1,Volt_L2,V,volt_l2,2
1,1-0:72.7.0*255(@1,Volt_L3,V,volt_l3,2
1,1-0:31.7.0*255(@1,Ampere_L1,A,volt_l1,2
1,1-0:51.7.0*255(@1,Ampere_L2,A,volt_l2,2
1,1-0:71.7.0*255(@1,Ampere_L3,A,volt_l3,2
1,1-0:21.7.0*255(@1,Watt_L1,W,watt_l1,0
1,1-0:41.7.0*255(@1,Watt_L2,W,watt_l2,0
1,1-0:61.7.0*255(@1,Watt_L3,W,watt_l3,0
Hager EHZ361
->sensor53 r
+1,3,o,16,9600,EHZ361,1
1,1-0:2.8.1*255(@1,Einspeisung HT,kWh,PoutHT,4
Hager EHZ363
->sensor53 r
+1,3,s,16,9600,EHZ363,1
1,=so1,00010800,65,5,65,5,000f0700
1,770701000f0700ff@1,akt. Leistung2,W,Power2,0
1,77070100200700ff@1,Voltage L1,V,Volt_p1,1
1,77070100340700ff@1,Voltage L2,V,Volt_p2,1
1,77070100480700ff@1,Voltage L3,V,Volt_p3,1
1,770701001f0700ff@1,Amperage L1,A,Amperage_p1,1
1,77070100330700ff@1,Amperage L2,A,Amperage_p2,1
1,77070100470700ff@1,Amperage L3,A,Amperage_p3,1
1,77070100510704ff@1,Phaseangle I-L1/U-L1,deg,phase_angle_p1,1
1,7707010051070fff@1,Phaseangle I-L27I-L2,deg,phase_angle_p2,1
1,7707010051071aff@1,Phaseangle I-L3/I-L3,deg,phase_angle_p3,1
1,770701000e0700ff@1,Frequency,Hz,frequency,0
